Flexstor H35 is a storage case for all 3.5" HDD. It provided dust-free protection and helps you file your data safely. Quick connect design allows easy SATA HDD connection.
- Ideal for safe HDD storage and organizing
- A clean dust free enclosure protects the HDD
- Quick connect design allows easy HDD connection
- Dimensions 157 × 118 × 31 mm
- Akasa Flexstor H35 - hard drive protective case
- Product Type
- Hard drive protective case
- 11.8 cm x 15.7 cm x 3.1 cm
- Black
- Product Type
- 11.8 cm
- 15.7 cm
- 3.1 cm
- Black
- Dust-resistant
