Your basket is empty
Akasa Flexstor H35 3.5" Hard Drive Protective Storage Case
Quicklinx: 86XKWS00 Mfr#: AK-HPC05-BK
Flexstor H35 is a storage case for all 3.5" HDD. It provided dust-free protection and helps you file your data safely. Quick connect design allows easy SATA HDD connection.
  • Ideal for safe HDD storage and organizing
  • A clean dust free enclosure protects the HDD
  • Quick connect design allows easy HDD connection
  • Dimensions 157 × 118 × 31 mm
Akasa Flexstor H35 - hard drive protective case
Hard drive protective case
11.8 cm x 15.7 cm x 3.1 cm
11.8 cm
15.7 cm
3.1 cm
Dust-resistant
