Akasa Euler Fanless Solid Aluminium Thin Mini-ITX Case
Quicklinx: 8DYNWS00 Mfr#: AK-ITX05-BK12UK
Euler Fanless Solid Aluminium Thin Mini-ITX Case: VESA Mountable with 120W external AC Adapter
  • Solid crafted aluminium case
  • Fanless CPU cooling design
  • Designed for thin mini-ITX motherboard
  • VESA mountable
  • Compatible with the following thin mini-ITX motherboard: Intel DQ77KB Ivy Bridge + Intel DH61AG Sandy Bridge
Specification
  • Material Aluminium with anodized black
  • Panel material Aluminium
  • Motherboards types Thin mini-ITX with DC onboard
  • Dimensions 228 x 187 x 61.5mm (WxDxH)
  • Weight 2200g
  • Internal bays 1 (for 2.5" HDD)
Akasa Euler - USFF - mini ITX
System cabinet
Ultra small form factor
Supported Motherboards
Mini-ITX
System Cabinet Features
VESA mounting interface
No power supply
22.8 cm x 18.7 cm x 6.15 cm
2.2 kg
Max Mainboard Size
Mini ITX
Mini-ITX
SATA cable, cable ties
No power supply
22.8 cm
18.7 cm
6.15 cm
2.2 kg
