Euler Fanless Solid Aluminium Thin Mini-ITX Case: VESA Mountable with 120W external AC Adapter
- Solid crafted aluminium case
- Fanless CPU cooling design
- Designed for thin mini-ITX motherboard
- VESA mountable
- Compatible with the following thin mini-ITX motherboard: Intel DQ77KB Ivy Bridge + Intel DH61AG Sandy Bridge
Specification
- Material Aluminium with anodized black
- Panel material Aluminium
- Motherboards types Thin mini-ITX with DC onboard
- Dimensions 228 x 187 x 61.5mm (WxDxH)
- Weight 2200g
- Internal bays 1 (for 2.5" HDD)
- Akasa Euler - USFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Ultra small form factor
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- VESA mounting interface
- Power Device
- No power supply
- 22.8 cm x 18.7 cm x 6.15 cm
- 2.2 kg
- Form Factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Included Accessories
- SATA cable, cable ties
- Power Device
- No power supply
- 22.8 cm
- 18.7 cm
- 6.15 cm
- 2.2 kg
