Your basket is empty
Akasa Echo compact and light foldable notebook cooler
Price Drop!
Cashback
Last Few Remaining
Price Drop
Quicklinx: 7H5BWS00 Mfr#: AK-NBC-29BK
Echo is perfect as a travel companion, compact and light. The folding design enables it to fit easily into a computer bag or briefcase, ready to use on the go. Two low noise fans effectively cool the notebook base, thereby keeping the internal PC fans quiet. Having your notebook running cool extends CPU, HDD and battery life.
Echo cooler is powered directly from a notebook and has a built in compartment for USB cable storage while not being used. The flip down feet for desktop use and rubber non-slip pads ensure stable and comfortable notebook operation.
Akasa Echo AK-NBC-29BK - notebook fan
Notebook fan
Matte black
Product Material
Aluminium, ABS plastic
30.7 cm x 16 cm x 2.7 cm
0.54 kg
Noise reduction
Notebook fan
Product Material
30.7 cm
16 cm
2.7 cm
0.54 kg
Matte black
Noise reduction
