Your basket is empty
Akasa DisplayPort to DVI Passive Converter 20cm
Quicklinx: BWF5WS00 Mfr#: AK-CBDP05-20BK
  • Easy connect a DisplayPort device to a DVI display
  • Supports extended desktop and video-mirroring display
  • Resolutions: 480i, 576i, 480p, 576p, 1080i, 1080p
  • Suitable only for graphics cards with DP++ output
  • DisplayPort latching connector ensure safe retention
  • Length: 20cm
Akasa display adapter - 20 cm
Display adapter
Latched, passive converter
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
DVI - female
Display adapter
Length
20 cm
Connector
20 pin DisplayPort - male
DVI - female
DisplayPort++
