Product
Brand
Akasa Connect 4SX 4 Port USB 3.0 Hub
Quicklinx: 91MDWS00 Mfr#: AK-HB-08BK
Connect 4SX Four port USB 3.0 Hub: USB 3.0 SuperSpeed connectivity.
USB bus powered supporting 1 TB external hard drive and 3 USB flash drives simultaneously.
  • Four port USB 3.0 hub
  • Plug and play
  • USB bus powered supporting 1 TB external hard drive and 3 USB flash drives simultaneously
  • USB 3.0 port backward compatible with USB 2.0
  • Application 4 ports USB 3.0 HUB
  • Standards USB 3.0 (USB 2.0 backwards compatible)
  • Power Mode USB powered
  • USB Ports Type A female USB 3.0 ports (downstream) * 4
  • Connector USB 3.0 type A
  • Data Transfer Rate Up to 5Gb/s - USB 3.0 / Up to 480 Mbit/s - USB 2.0
  • Product Code AK-HB-08BK
Akasa Connect4SX - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 2.0, USB 3.0
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
USB 2.0, USB 3.0
5 x USB 3.0 Type A
1 x SuperSpeed USB cable
Plug and Play
