The AK-865 is a new design cooler combining lo-noise, efficient cooling with great value. Only 50mm of height (including fan) means it can be installed even in very compact cases. Hi-engineered aluminium heatsink and quiet 80mm fan ensure optimized performance with all AMD processors up to 89W or TDP. Thermal compound is pre-applied.
- High engineered aluminium heatsink for cost effective cooling performance
- 8 cm low noise high performance fan
- new design one point clip enables quick and safe retention
- 3-pin fan connector Hi-grade thermal interface pre-applied
