Your basket is empty
Akasa 8cm Blue uV Reactive Fan Low Noise
Quicklinx: 36W2WS00 Mfr#: AK-176BL-S
Type: Case Fan
£3.10 ex VAT
£3.72 inc VAT
AK-176BL-S Keep your cool with Akasa UV reactive case fans. Blue, Green or Orange, cool it with colour.
  • Blue UV reactive fan
  • Lo-noise case fan
  • Blue UV 3 to 4-pin adapter
  • 4 case screws
Akasa AK 176BL-S - system fan kit
System fan kit
UV-blue
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
2500 rpm
Air Flow
32.4 cfm
Noise Level
27.85 dBA
Power Connector
3-pin plug, 4 pin Molex connector
80 mm x 80 mm x 25 mm
Package Type
Retail
System fan kit
80 mm
80 mm
25 mm
UV-blue
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
2500 rpm
Air Flow
32.4 cfm
Noise Level
27.85 dBA
Power Connector
Mounting Kit
Included
Package Type
Retail
Akasa 8cm Blue uV Reactive Fan Low Noise                Bundle deal on Akasa 8cm Blue uV Reactive Fan Low Noise
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.35 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £1.60 | while stocks last
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.47 | in stock
£19.15
saving £7.01
Type: Case Fan
Brand: Akasa
Price Range Ex VAT: 0 - 50
