Akasa is the leader in thermal integration solutions. Basing on quality and consistency, Akasa continues to produce new and innovative components to excite the high-end market.
PRODUCT FEATURES:
- 8cm Crystal Blue Fan
- 4 Blue Color LEDs
- Fan life expectancy 30,000 hours
- 3pin Connector
- Akasa AK 170CB-4BLS fan unit
- Product Type
- Fan unit
- Crystal blue
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 2500 rpm
- Air Flow
- 28.8 cfm
- Noise Level
- 27.45 dBA
- Product Type
- Fan unit
- Crystal blue
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 2500 rpm
- Air Flow
- 28.8 cfm
- Noise Level
- 27.45 dBA
Customer reviews
Write a review for the Akasa 80mm Crystal Blue case Fan - Blue LED here!
best value and wicked colour
Reviewed by . Review Posted 31/05/2008
Great colour especially against black case, quiet and you cant beat the price on-line or on the high street.
Had to create screw teeth (bit screw fits into couldn't remember name)
But just connect it to power supply to find out which way is which. screw the screws in and hey prestow.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
