650W modular PSU, use the cable you need to reduce clutter. Akasa Cobra PSU features Dynamic single 12V rail for power hungry hardware.
- Modular cable management enhances airflow.
- Dynamic single 12V rail for power hungry hardware.
- Thermally controlled ultra-quiet fan.
- COBRA strip cable is neat and manageable.
- Akasa Cobra 650 - power supply - 650 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- Localisation
- United Kingdom
- Input Voltage
- AC 240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- +3.3V - 22 A , +5V - 22 A , +12V - 49 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- 15 cm x 16 cm x 8.6 cm
- ATX12V 2.3
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 240 V
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- Efficiency
- 82%
- Cooling System
- 135 mm fan
- Over current protection, over voltage protection, overpower protection, cable management, single 12V rail, temperature controlled fan
- 15 cm
- 16 cm
- 8.6 cm
