Your basket is empty
Akasa 550W Dual 12V Rail PSU
Quicklinx: 78FHWS00 Mfr#: AK-P550AG8-SLUK
ES is the entry level series of Akasa power supplies. These can be described as reliable, highly efficient and affordable. The ES power supplies have been designed with a no frills approach but still include many of the important features found on high-end power supplies.
Over 80% efficiency and built in active PFC provides energy saving clean power. The Ultra quiet thermally controlled 12cm fan ensures efficient cooling. Strong 12V output balanced on two rails delivers reliable system performance.
Fully sleeved cables complete with a generous number of connectors, including PCIe for graphics support. This provides great compatibility and makes it an ideal choice for mainstream and basic computing systems of today and the future.
  • Energy saving active PFC
  • Over 80% efficient
  • Thermally controlled ultra quiet fan
  • Dual 12V rail for stable power delivery
  • Two PCIe connectors
  • Fully sleeved cables with black mesh
  • Suitable for bottom case mounting
Spec
  • Application 550W PC Power Supply
  • Designed for AMD / INTEL based systems
  • ATI-AMD / NVIDIA graphics
  • Form factor ATX 12V 2.3
  • Dimensions 150 x 140 x 86mm
  • Typical efficiency Over 80%
  • Power Factor Correction Active PFC
  • Fan 120 x 120 x 25mm, thermal control
  • Motherboard connector 1 (20+4pin )
  • ATX12V connectors 1 (4pin)
  • PCIe 6+2pin connectors 1
  • PCIe 6pin connectors 1
  • SATA connectors 4
  • Molex 4pin connectors 3
  • FDD 4pin connectors 1
  • Cable sleeve Black mesh (all cables, full length)
  • AC power input 220~240V AC
  • Protection Over Power / Voltage / Current Protection
  • Safety CE, CB
Akasa ES Power - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
United Kingdom
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output connectors
4 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 6 pin PCI Express power , 1 x power 4 pin ATX12V connector , 1 x power 24 pin ATX with detachable 4 pin section
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
ATX12V 2.3
PSU Form Factor
ATX
United Kingdom
Input Voltage Range
AC 220 - 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 30 A , +5V - 35 A , +12V1 - 22 A , +12V2 - 20 A , -12V - 0.5 A , +5VSB - 2.5 A
Efficiency
80%
Power cable
Cooling System
120 mm fan
Over current protection, over voltage protection, overpower protection
CB
15 cm
14 cm
8.6 cm
