Your basket is empty
Akasa 5.25" Akasa Interconnect PRO, Aluminium Panel with USB
Quicklinx: 8MRLWS00 Mfr#: AK-HC-05U3BK
Conveniently positioned at the front of your PC, this six slot media card reader accepts most available cards in a single location. It includes additional USB ports and eSATA port for extra connectivity. It is easy to install.
Akasa InterConnect Pro - card reader - USB 3.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card
Host Interface
USB 3.0
Required Bay
5.25" internal
Brushed aluminum
Built-in USB hub
Host Interface
USB 3.0
Required Bay
5.25" internal
Brushed aluminum
Built-in USB hub
Additional Ports
1 x USB 2.0 , 2 x USB 3.0 , 3 x eSATA
Microsoft Windows 2000 / XP, Microsoft Windows Vista / 7 / 8
