Product
Brand
Akasa 30cm PWM Fan Extension Cable
Quicklinx: 7M9BWS00 Mfr#: AK-CBFA01-30
PWM fan extension cable: 30cm cable with 4pin connectors for PWM and 3pin fans
PWM fan extension cable. 4pin connectors compatible with PWM and 3pin fans. 30cm black sleeve smart look cable for compatibility with tall chassis and better cable routing.
  • 4pin PWM and 3pin fans compatible
  • Black sleeve
  • Length: 30cm
  • Connectors Male to female 4pin PWM connectors
  • Colour Black
Akasa fan power extension cable - 30 cm
Fan power extension cable
Length
30 cm
Connector
4 pin PWM - female
Connector (Second End)
4 pin PWM - male
Length
30 cm
Connector
4 pin PWM - female
4 pin PWM - male
