Mounting adapter allows a 3.5" device, 3.5" HDD or 2.5" SSD/HDD to fit into a 5.25" PC drive bay.
Spec
- Application Mounts single 3.5" device, 3.5" HDD or 2.5" SSD/HDD in a 5.25" PC bay
- Designed for 3.5" device, 3.5" HDD or 2.5" SSD/HDD
- Material Plastic
- Dimensions 154.5(L) x 149(W) x 42.2(H) mm
- Weight 96g
- Akasa AK-HDA-05 - storage bay adapter
- Storage bay adapter
- Supported Form Factor
- 5.25" to 3.5" / 2.5"
- Expansion Bays
- 1 x internal - 2.5" / 3.5" shared
- Compatible Bay
- 1 5.25"
- Product Material
- Plastic
- 14.9 cm x 15.5 cm x 4.2 cm
- 96 g
- Product Material
- Plastic
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 5.25"
- 14.9 cm
- 15.5 cm
- 4.2 cm
- 96 g
