Your basket is empty
Akasa 3.5" Internal 6-Slot Multicard Reader with USB 3.0
Quicklinx: 7M8YWS00 Mfr#: AK-ICR-07U3
Makes reading media cards so much easier
Conveniently positioned at the front of your PC, this six slot media card reader accepts most available cards in a single location. Includes a SuperSpeed USB3.0 port for fast connectivity. Choice of black or classic-white front facia plates. Simple installation.
  • Super speed USB3.0 connection
  • Backwards compatible with USB2.0
  • 6-slots card reader
  • Choice of fascia colour
Specification
  • Application 3.5" PC bay
  • Memory card slots 6
  • Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) , 64GByte for SDXC - 32GByte for SDHC Extreme Digital (X card, Type H, Type M) M2 (Memory Stick Micro M2) microSD (microSDHC, High Capacity)
  • Interface 5Gb/s (USB3.0) and 480Mb/s (USB2.0)
  • Data transfer rate USB 3.0 port: up to 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
  • Card reader: up to 480 Mb/s
  • LED indication Power On, Card In & Data Transfer
  • Power mode USB powered
  • PC connection Internal USB motherboard header, USB3.0 A male connector
  • Supported OS Windows 2000 / XP / VISTA / 7
  • Plug & Play Supported
Please note the USB 3.0 connection is acheived via an external cable. If you required internal USB 3.0 connection via a 19pin header please consider QL 8205 (Akasa Code: AK-ICR-14)
Akasa Internal Card Reader - card reader - USB 3.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
Host Interface
USB 3.0
Required Bay
3.5" internal
Host Interface
USB 3.0
Required Bay
3.5" internal
Microsoft Windows 2000/XP/Vista/7
