Your basket is empty
Akasa 3.5" Internal 5-Slot Multicard Read with eSATA & USB
Quicklinx: 83G3WS00 Mfr#: AK-ICR-16
Supported Formats: SDXC Memory Card
Interface: USB 2.0
£15.36 ex VAT
£18.43 inc VAT
  • SuperSpeed USB 3.0 port
  • Five slot memory card reader
  • USB 2.0 HUB
  • Three card-slots are active at the same time, allowing cross format data transfer
  • USB 2.0 HUB with independent power design
  • USB 3.0 port backwards compatible with USB 2.0
Spec
  • Application 3.5" PC bay
  • Memory card slots 5
  • Memory card types: Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile / 64GByte for SDXC - 32GByte for SDHC / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
  • Rear connector Internal USB 2.0 motherboard connector, internal USB 3.0 motherboard connector, SATA connector, 4-Pin PSU molex connector. Data transfer rate 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
  • LED indication Power On, Card In & Data Transfer
  • Power mode USB and 4-Pin PSU molex
  • Supported OS Windows 2000 / XP / VISTA / 7
  • Plug & Play Supported
  • Product code AK-ICR-16
Internal USB 2.0 motherboard connector, internal USB 3.0 19pins motherboard connector, SATA connector, 4-Pin PSU molex connector
Akasa AK-ICR-16 - card reader - USB 2.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, CompactFlash Card, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card
Host Interface
USB 2.0
Required Bay
3.5" internal
Built-in USB hub, status indicator
Host Interface
USB 2.0
Required Bay
3.5" internal
Required Ports
1 x 4 pin USB Type A , 1 x 9 pin USB Type A , 1 x 7 pin external Serial ATA
Microsoft Windows 2000/XP/Vista/7
Plug and Play
Interface: USB 2.0
Brand: Akasa
Price Range Ex VAT: 0 - 50
