Akasa 3.5" Internal 4-Port USB Panel, 2 x USB 3.0 & 2 x USB 2.0
Quicklinx: 90C5WS00 Mfr#: AK-ICR-12V3
The akasa connect panel locates in PC chassis 3.5" drive bay and gathers all USB data connections in one easy accessible place. Additional two USB 2.0 and two USB 3.0 expand the system real-time connectivity to create computing experience with no limitations.
  • SuperSpeed USB 3.0 connection
  • Backwards compatible with USB 2.0
  • Easy to install
  • Application 4 port USB panel
  • Data transfer rate up to 5Gb/s - USB 3.0 up to 480 Mbit/s - USB 2.0
  • USB 3.0 ports 2
  • USB 2.0 ports 2
  • PC connection internal motherboard USB 2.0 connector
  • internal motherboard USB 3.0 connector
  • Supported OS Windows 2000 / XP / Vista / 7
  • Plug & Play Yes
  • Product code AK-ICR-12V3
Akasa InterConnect S - storage bay ports panel
Storage bay ports panel
Ports
USB 2.0 x 2, USB 3.0 x 2
Microsoft Windows 2000/XP/Vista/7
Compatible Bay
3.5"
Interface Provided
Connector Provided
4 pin USB Type A x 2 , 9 pin USB Type A x 2
Mounting Kit
Included
Plug and Play
