The akasa connect panel locates in PC chassis 3.5" drive bay and gathers all USB data connections in one easy accessible place. Additional two USB 2.0 and two USB 3.0 expand the system real-time connectivity to create computing experience with no limitations.
- SuperSpeed USB 3.0 connection
- Backwards compatible with USB 2.0
- Easy to install
- Application 4 port USB panel
- Data transfer rate up to 5Gb/s - USB 3.0 up to 480 Mbit/s - USB 2.0
- USB 3.0 ports 2
- USB 2.0 ports 2
- PC connection internal motherboard USB 2.0 connector
- internal motherboard USB 3.0 connector
- Supported OS Windows 2000 / XP / Vista / 7
- Plug & Play Yes
- Product code AK-ICR-12V3
- Akasa InterConnect S - storage bay ports panel
- Product Type
- Storage bay ports panel
- Ports
- USB 2.0 x 2, USB 3.0 x 2
- System Requirements
- Microsoft Windows 2000/XP/Vista/7
- Product Type
- Compatible Bay
- 3.5"
Interface Provided
- Connector Provided
- 4 pin USB Type A x 2 , 9 pin USB Type A x 2
- Mounting Kit
- Included
- Plug and Play
- OS Required
