Product
Brand
Akasa 22cm Ultra Quiet Fan with 5 Blue LED Lights
Quicklinx: 4XSXWS00 Mfr#: AK-FN066-CB
Ultra quiet 22cm clear PC case fan. Ideal for DIY modding or as a replacement for existing 22cm chassis fans.
Akasa AK F2230SM-CB - case fan
Case fan
Crystal Clear
Fan Diameter
220 mm
Fan Height
30 mm
Fan Bearing
Sleeve bearing
Rotation Speed
600 rpm
Air Flow
95.6 cfm
Power Connector
4 pin Molex connector
Blue LED x5
22 cm x 22 cm x 3 cm
Case fan
22 cm
22 cm
3 cm
Crystal Clear
Heatsink & Fan
Fan Diameter
220 mm
Fan Height
30 mm
Fan Bearing
Sleeve bearing
Rotation Speed
600 rpm
Air Flow
95.6 cfm
Power Connector
Blue LED x5
Mounting Kit
Included
Sound Emission
23 dBA
