14cm APACHE Black: S-FLOW fan blade design delivers 30% higher airflow.
Super silent 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction.It's powerful and quiet!
- Super silent APACHE BLACK 14cm fan
- S-FLOW fan blade design delivers 30% higher airflow
- Super silent with PWM speed control
- Hydro Dynamic Bearing extends fan life
- Application PC case or heatsink fan
- Dimension 140 X 140 X 25mm
- Fan speed 600 -1300 RPM
- Max airflow 89.55 CFM
- Max static air pressure 2.76 mm H2O
- Noise level 12.5 -22.19 dB(A)
- Voltage rating 12V DC
- Bearing HDB (Hydro Dynamic Bearing)
- Fan life expectancy 50,000 hours
- Connector 4pin PWM
- Akasa APACHE AK-FN062 - case fan
- Product Type
- Case fan
- Black
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydrodynamic bearing
- Rotation Speed
- 600-1300 rpm
- Air Flow
- 89.6 cfm
- Noise Level
- 12.5 - 22.2 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 14 cm x 14 cm x 2.5 cm
- Anti-vibration
- Product Type
- Case fan
- 14 cm
- 14 cm
- 2.5 cm
- Black
Heatsink & Fan
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 600-1300 rpm
- Air Flow
- 89.6 cfm
- Air Pressure
- 2.76 mm
- Noise Level
- 12.5 - 22.2 dBA
- Power Connector
- Rated Voltage
- 12 V
- Mounting Kit
- Included
- Anti-vibration
