This near silent 12 cm fan with distinctive Emperor Blue colored rotor blades and crystal clear frame is designed with low air impedance blades providing the ultra quiet acoustic experience.
- Akasa AK-191-BL - case fan
- Product Type
- Case fan
- Crystal Clear, emperor blue
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 38.4 cfm
- Power Connector
- 3-pin plug
- 12 cm x 12 cm x 2.5 cm
- Product Type
- Case fan
- 12 cm
- 12 cm
- 2.5 cm
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 38.4 cfm
- Power Connector
- 3-pin plug
- Sound Emission
- 17.5 dBA
Customer reviews
Write a review for the Akasa 12cm Silent Blue Case Fan here!
Akasa 12CM SILENT BLUE FAN.
Reviewed by Anonymous Review Posted 04/09/2008
I used the screws that came with my new case to fit this, so i guess i was lucky i didn't have to use the crappy self tappers that come with this fan. In it's defense though, the actual fan seems of very high quality and also looks nice.
- Overall
- Ease of use
- Value for money
Way over priced!!!!!!!
Reviewed by Anonymous Review Posted 09/01/2008
Akasa AK-191BL 12cm Silent Blue Fan
The Akasa AK-191BL: 12cm Silent Blue Fan.
£3.90
LambdaTek
- Overall
- Ease of use
- Value for money
great fan, cheap screws
Reviewed by . Review Posted 04/09/2008
great fan, just use different screws than the ones provided. Having this as an exhaust and it's 8cm cousin as an intake reduced my case temp by 10c.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
