Product
Brand
Akasa 12cm Piranha Air Ripper, Max air pressure and massive airflo
Quicklinx: 8DSVWS00 Mfr#: AK-FN072
Supporting fully automatic PWM speed control, the PIRANHA uses custom design PWM IC that integrates Soft Switching Commutation (SSC) technology.
Akasa Piranha AK-FN072 - case fan
Case fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-1900 rpm
Air Flow
79.1 cfm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Anti-vibration
Case fan
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1900 rpm
Air Flow
79.1 cfm
Air Pressure
3.04 mm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Anti-vibration
