This is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The bright Green illumination is achieved by four hi-bright green LED complemented with a crystal green frame and blades.
The fan glows a fantastic green, which adds color and style to any PC system.
- Akasa Quiet Bright Green AK-274CG-4GNS - case fan
- Product Type
- Case fan
- Package Content
- Screws, 3-pin plug to 4-pin Molex adapter
- Crystal green
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 38.4 cfm
- Power Connector
- 3-pin plug, 4 pin Molex connector
- Variable fan speed, green LED x4
- 12 cm x 12 cm x 2.5 cm
- Product Type
- Case fan
- Package Content
- 12 cm
- 12 cm
- 2.5 cm
- Crystal green
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 38.4 cfm
- Power Connector
- Sound Emission
- 17.5 dBA
