Your basket is empty
Akasa 120mm Smart & Cool PWM Case Fan
Quicklinx: 5CNBWS00 Mfr#: AK-FN053
Type: Case Fan
£4.60 ex VAT
£5.52 inc VAT
Akasa smart & cool motherboard controlled fans provide an ideal solution for combining ultra quiet and performance computing. Crystal clear fan frame and distinctive emperor blue blades provides precise controlled cooling by utilizing the motherboard PWM feature. PWM is more accurate, energy saving and fully automatic way of controlling the fan speed (RPM). (compared to voltage regulation) PWM is widely available on all current Intel and AMD platform based motherboards and it enables ultra quiet acoustics during normal PC use and high performance cooling under high system load. Clever fans can be used on a CPU cooler as well as a chassis or radiator fans.
Akasa smart&cool AK-FN053 - case fan
Case fan
Crystal Clear, emperor blue
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
500-1500 rpm
Air Flow
17.4-50.5 cfm
Power Connector
4 pin Molex connector
Pulse-width modulation (PWM) support
Anti-vibration
Case fan
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
500-1500 rpm
Air Flow
17.4-50.5 cfm
Power Connector
Mounting Kit
Included
Anti-vibration
Sound Emission
18.3 dBA
Akasa 120mm Smart & Cool PWM Case Fan Bundle deal on Akasa 120mm Smart & Cool PWM Case Fan
£25.79
saving £14.13
Type: Case Fan
Brand: Akasa
Price Range Ex VAT: 0 - 50
