Product
Brand
Akasa 120mm Black Apache Fan , PWM, Dust and moisture proof super silent fan, HDB Bearing
Quicklinx: 6NVWWS00 Mfr#: AK-FN058
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It's powerful, quiet and tough!
  • Super silent APACHE BLACK 12cm fan
  • S-FLOW fan blade design delivers 30% higher airflow
  • IP-54 military standard moisture and dust protection
  • Super silent with PWM speed control
  • Hydro Dynamic Bearing extends fan life
Application
PC Case or heatsink fan
Dimensions
120 x 120 x 25mm
Fan speed
600 -1300 RPM
Max airflow
57.53 CFM (97.74 m3/h)
Max static air pressure
2.64 mm H2O
Noise level
6.9 -16.05 dB(A)
Current rating
0.33A
Voltage rating
12V DC
Bearing
HDB (Hydro Dynamic)
Fan life expectancy
50,000 hours
Connector
4 pin PWM
