The SC-22 features an LED backlight 22" widescreen display with a full HD 1920 x 1080 resolution, delivering high picture clarity. Quick signal-switching and rapid response time guarantees surveillance efficiency. With analog, HDMI, and looping BNC I/O, the SC-22 is easily integrated into any security system. Auto NTSC/PAL detection and auto settings adjustment reduce maintenance effort. Coming with built-in speakers and stylish slim profile, the SC-22 is the ideal value display choice for security and surveillance environments.
- Neovo SC-22 LCD display
- LCD display
- Recommended Use
- Surveillance system
- Colour Support
- Display Size
- 22"
- Viewable Area
- 21.5"
- Resolution
- 1920 x 1080
- LCD Technology
- TFT active matrix
- Video Format
- NTSC, PAL
- Image Brightness
- 250 cd/m²
- Supported Video Signals
- S-Video, composite video, VGA, HDMI
- High Definition Monitor
- Built-in Speakers
- 2 speakers
- Video noise reduction, 3D comb filter, LED backlight, Anti-Burn-in technology
- Kit Content
- 1 x VGA cable , 1 x audio cable
- Voltage Required
- AC 120/230 V
- Power Consumption
- 21 Watt
- LCD display
- 51.65 cm
- 18.5 cm
- 37.6 cm
- 2.4 kg
CCTV
- Equipment Category
- CCTV monitors
- S-Video, composite video, VGA, HDMI; NTSC, PAL
- Audio Support
Studio & Field Monitors
- Recommended Use
- Colour Support
- Display Size
- 22"
- Viewable Area
- 21.5"
- Native Resolution
- 1920 x 1080
- LCD Technology
- TFT active matrix
- Image Brightness
- 250 cd/m²
- Built-in Speakers
- 2 speakers
- Voltage Required
- AC 120/230 V
- Frequency
- 50/60 Hz
- Power Consumption
- 21 Watt
Kit Content
- Kit Content
- (1) x VGA cable , (1) x audio cable
Terminals
- Terminals
- (1) x VGA input - 15 pin HD D-Sub (HD-15) , (1) x S-video input - 4 PIN mini-DIN , (1) x composite video input - BNC - with loop through , (1) x audio line-in - mini-phone stereo 3.5 mm , (1) x HDMI input - 19 pin HDMI Type A , (1) x audio line-out - mini-phone stereo 3.5 mm
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
- Shipping Width
- 56.5 cm
- Shipping Depth
- 11.6 cm
- Shipping Height
- 42 cm
- Shipping Weight
- 4.5 kg
