AG Neovo Mounting kit for 2 LCD displays
Quicklinx: BL2DWS00 Mfr#: DMC-02D
Accessory Type: Mount
£125.85 ex VAT
£151.02 inc VAT
Control over dual display images and save space with the DMC-02D desk clamp. The ergonomic design allows rapid tilt, swivel, rotation as well as height adjustment. With the sturdy hinges and body structure, the DMC-02D bears display weight up to 12 kg per hinge and endures long time operations. Compatible with VESA standard, it supports a wide range of displays under 24".
Neovo DMC-02D - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Desk clamp mount
67.2 cm x 14.4 cm x 47 cm
3.3 kg
Recommended Use
2 LCD displays
Recommended Display Size
24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
12 kg
Material
Plastic, steel, aluminium alloy
Black, silver
67.2 cm
14.4 cm
47 cm
3.3 kg
Material
Black, silver
AV Furniture
Mounting kit
Mounting Components
Desk clamp mount
Design
Tilt & Swivel
Recommended Use
2 LCD displays
Cable Management
Integrated cable management
24"
Max Load Weight
12 kg
Adjustable height, durable
Brand: AG Neovo
Price Range Ex VAT: 100 - 150
