Adaptec 82885T SAS Expander Card
Quicklinx: BMXHWS00 Mfr#: 2283400-R
The Adaptec 82885T SAS expander card offers a scalable connectivity/fan-out option for additional drives when used in conjunction with a SAS RAID adapter or SAS HBA. The 82885T SAS Expander Card offers ports in a low-profile MD2 form factor with internal ports for connection to a SAS adapter and/or SAS or SATA drives and external ports for optional connections to external JBODs or a SAS adapter.
  • Flexibility of configuration
    The 82885T mounts internally to any available PCIe slot, away from the backplane, and features mini-SAS HD connectors out the top for added cabling flexibility in dense server environments. The 82885T enables a low cost drive expansion solution when mated with a RAID adapter or HBA. The expander draws power from the PCIe slot, but there is no data transfer to the slot. Alternatively, power can also be supplied to the expander card through a standard auxiliary power connector.
  • Enclosure management support
    The 82885T supports SGPIO and SES2 enclosure management, allowing enclosure information to be routed from all daisy-chained 82885T cards to the HBA or RAID adapter. All device and slot mapping information is provided to the HBA or RAID adapter by the last 82885T card in the chain.
  • Universal compatibility with existing storage infrastructure
    The 82885T is fully compatible with RAID adapters and HBAs, allowing for a seamless integration and management within an end-to-end Adaptec solution. The 82885T is also compatible with 3rd party adapters and HBAs and has also been tested for interoperability with a wide variety of SAS and SATA HDDs and SSDs.
Microchip Adaptec 82885T - storage SAS bus extender - SATA 6Gb/s / SAS 12Gb/s - PCIe x4
Storage SAS bus extender - plug-in card - low profile
Bus Type
PCIe x4
Data Transfer Rate
12 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
36
16.7 cm x 6.4 cm
3-year warranty
Host Bus
PCIe x4
Storage Controller
Data Transfer Rate
12 Gbit/s
Supported Devices
Channel Qty
36
7 x SATA 6Gb/s / SAS 12Gb/s - 4 x Mini SAS HD (SFF-8643) (internal) , 2 x SATA 6Gb/s / SAS 12Gb/s - 36 pin 4x Shielded Mini MultiLane (external)
MTBF
1,000,000 hour(s)
UL, VCCI, C-Tick, FCC, RoHS, KCC
Limited warranty - 3 years
16.7 cm
6.4 cm
55 °C
