Get ready for a whole new gaming experience. Get wrapped up in your games with a massive curved display with 144Hz refresh rate and Adaptive-Sync. Combined with DTS Sound, multitasking and great design, this monitor is worthy of the most demanding gaming setups.
Curved display
The curve is for top-end gaming. Enjoy a completely cinematic gaming experience with a massive 35" UltraWide 21:9 Full HD display. With a whopping 100% sRGB, you'll be amazed at the rich colors that bring your game worlds to life. -
Accelerated gaming
A super-charged 144Hz refresh rate gives you all the speed you need to dominate your opponents and get the most out of your graphics card. Find opponents before they spot you and enjoy crystal clear curves on the racetrack. -
Adaptive-Sync
Say goodbye to screen tearing with Adaptive-Sync technology. You'll never go back to gaming without it after seeing your favorite titles running more smoothly than you ever thought possible. -
Stay comfortable
Stay in the fight for hours with Acer EyeProtect's flicker-less, blue-light filter, ComfyView and Low-dimming technology. Give your neck a break too, with flexible tilt and height adjustments. -
Clever design
Designed specifically for passionate gamers, the XZ Series features customizable ambient lighting, Acer GameView to tweak display settings, user-selectable aim points, HDMI 2.0 for better display bandwidth and a futuristic design with striking angles. -
Bold audio
DTS Sound speakers and Acer TrueHarmony technology provide a powerful sound you'd never expect from your display. Toss out your old desk speakers and enjoy world-class audio with all of your entertainment.
- Acer XZ350CU - LED monitor - curved - 35"
- LED-backlit LCD monitor - 35"
- Energy Class
- Class B
- Energy Consumption per Year
- 76 kWh
- Power Consumption (On mode)
- 52 W
- Curved Screen
- Adaptive-Sync Technology
- VESA Adaptive-Sync
- Daisy Chaining
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080 at 144 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort, HDMI (MHL)
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 76 kWh
- Diagonal Size
- 35"
- Curved Screen
- Daisy Chaining
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Blue Light Filter technology, Acer TrueHarmony, DTS Sound, 2000R curvature, adjustable ambient lighting
- Black
Audio
- Speakers - stereo
- Output Power / Channel
- 9 Watt
- HDMI , MHL / HDMI , DisplayPort , DisplayPort output , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Height, tilt
- Tilt Angle
- -5/+25
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Integrated cable management, VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable
- MPR II
- Input Voltage
- 52 W
- Power Consumption (Typical)
- 42 Watt
- Power Consumption Sleep
- 1.2 Watt
- Limited warranty - 2 years
