Product
Acer XZ321Qbmijpphzx 31.5" 1920x1080 HDMI DP USB Gaming Monitor
Quicklinx: CPC2WS00 Mfr#: UM.JX1EE.005
Diagonal Size: 31.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£359.54 ex VAT
£431.44 inc VAT
The curve is in for top-end gaming. Enjoy a completely cinematic gaming experience with a massive ultra-wide display. With a whopping RGB, you'll be amazed at the rich colors that bring your game worlds to life. A super-charged refresh rate gives you all the speed you need to dominate your opponents and get the most out of your graphics card. Find opponents before they spot you and enjoy crystal clear curves on the racetrack. Say goodbye to screen tearing with Adaptive-Sync technology. You'll never go back to gaming without it after you see your favorite titles running more smoothly than you ever thought possible. Stay in the fight for hours with Acer EyeProtect's Flicker-less, Blue-light Filter, ComfyView and Low-dimming technology. Give your neck a break too, with flexible tilt and height adjustments. Designed specifically for passionate gamers, the XZ series features customizable ambient lighting, HDMI for better display bandwidth and a futuristic design with striking angles.
  • Curved display
  • Accelerated gaming
  • Adaptive-Sync
  • Stay comfortable
  • Clever design
Acer XZ321Q - LED monitor - curved - Full HD (1080p) - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class A
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB Hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare
Black, silver
2 years warranty
Display Type
Energy Class
Class A
59 kWh
40 W
Diagonal Size
31.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Built-in Devices
USB Hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Screen Coating
Anti-glare
Backlight Technology
LED backlight
72% NTSC colour gamut, DTS Surround Sound, Acer VisionCare, Acer BluelightShield technology, 178° horizontal and vertical viewing angle
Black, silver
Audio
Speakers
Output Power / Channel
7 Watt
HDMI , MHL / HDMI , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+25
Rotation Angle
60
Height Adjustment
120 mm
Flat Panel Mount Interface
1 x DisplayPort cable , 1 x SuperSpeed USB cable
AC 120/230 V
31.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.45 Watt
Acer XZ321Qbmijpphzx 31.5 Bundle deal on Acer XZ321Qbmijpphzx 31.5" 1920x1080 HDMI DP USB Gaming Monitor
£459.30
Response Time: 4ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 300 - 500
