Product
Acer XR382CQKbmijphuzx 37.5" 3840x1600 HDMI DP USB Gaming Monitor
Quicklinx: CPBYWS00 Mfr#: UM.TX2EE.005
Diagonal Size: 37.5in
Max Resolution: 3840 x 1600
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
£1,072.41 ex VAT
£1,286.89 inc VAT
An incredible resolution and a curved 21:9 aspect ratio widescreen give you a truly panoramic view. Easy adjustments and special picture modes allow you to fully customize your viewing experience.
  • Flickerless technology
    Reduces annoying screen flickering that can cause eye strain when viewing the monitor for long periods.
  • 21:9 aspect ratio
    Get all the benefits of Full HD in an ultra-wide format. Superb for movies and for viewing documents side by side.
  • USB 3.0
    Easily transfer text and data files, photos and even movies at faster speeds.
Acer XR382CQK - LED monitor - curved - 37.5"
LED-backlit LCD monitor - 37.5"
Energy Class
Class B
Energy Consumption per Year
85 kWh
Power Consumption (On mode)
58 W
Curved Screen
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3840 x 1600 at 75 Hz
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Silver
Image Colour Disclaimer
The displayed product image may be a different colour
89.688 cm x 30.9 cm x 46.177 cm
10.9 kg
Display Type
Energy Class
Class B
85 kWh
58 W
Diagonal Size
37.5"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
172
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, ambient light sensor, picture by picture, Acer EcoDisplay, 100% sRGB colour gamut, Zero Frame, daisy chain compatible, Flicker-Less technology, Blue Light Filter technology, DTS Sound, Adaptive-Sync technology
Silver
89.688 cm x 30.9 cm x 46.177 cm - with stand
10.9 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
HDMI , MHL / HDMI , DisplayPort , DisplayPort output , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Height Adjustment
130 mm
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable
58 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.48 Watt
Acer XR382CQKbmijphuzx 37.5 Bundle deal on Acer XR382CQKbmijphuzx 37.5" 3840x1600 HDMI DP USB Gaming Monitor
£1,167.42
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Acer
Price Range Ex VAT: 1000 - 1500
