Your basket is empty
Acer XR382CQKbmijphuzx 37.5" 3840x1600 HDMI DP USB Gaming Monitor
Quicklinx: CPBYWS00 Mfr#: UM.TX2EE.005
Diagonal Size: 37.5in
Max Resolution: 3840 x 1600
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
Hurry, only 2 left in stock!
£1,081.31 ex VAT
£1,297.57 inc VAT
An incredible resolution and a curved 21:9 aspect ratio widescreen give you a truly panoramic view. Easy adjustments and special picture modes allow you to fully customize your viewing experience.
Acer XR382CQK - LED monitor - curved - 37.5"
LED-backlit LCD monitor - 37.5"
Energy Class
Class B
Energy Consumption per Year
85 kWh
Power Consumption (On mode)
58 W
Curved Screen
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3840 x 1600 at 75 Hz
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Silver
89.688 cm x 30.9 cm x 46.177 cm
10.9 kg
Display Type
Energy Class
Class B
85 kWh
58 W
Diagonal Size
37.5"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
172
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, ambient light sensor, picture by picture, Acer EcoDisplay, 100% sRGB colour gamut, Zero Frame, daisy chain compatible, Flicker-Less technology, Blue Light Filter technology, DTS Sound, Adaptive-Sync technology
Silver
Image Colour Disclaimer
The displayed product image may be a different colour
89.688 cm x 30.9 cm x 46.177 cm - with stand
10.9 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
HDMI , MHL / HDMI , DisplayPort , DisplayPort output , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Height Adjustment
130 mm
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable
58 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.48 Watt
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Acer
Price Range Ex VAT: 1000 - 1500
