Game like you mean it
Acer XF Series gaming monitors range from Full HD to WQHD resolutions, with aspect ratios from 16:9 up to mega-immersive Ultrawide 21:9. Add to that you get AMD® FreeSync™, a 144Hz2 refresh rate and a 1ms* response time, and you get the gaming you deserve.
Pixel Powered
Acer XF Series monitors are designed to push your pixels to the max. IPS1 technology2 provides wide views and enhanced colour with 100% sRGB colour gamut2. A rapid 144Hz refresh rate2 smooths out 2D action. Add the 1ms response time2 and you’ve got pixel power.
Smoothed gaming
Slide through your ride with AMD® FreeSync™. FreeSync™ technology eliminates screen tearing and minimises stuttering by syncing the display refresh rate with the frames output by your computer’s display card. PC gaming doesn’t get much smoother.
Vision protected
Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren’t the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine.
All the right moves
Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed.
It’s easy being green
The entire XF line also has multiple green design certifications that attest to our commitment to producing products that are both great and green.
Nitro XF0
Game like you mean it -
Pixel Powered
Acer XF Series monitors are designed to push your pixels to the max. IPS technology provides wide views and enhanced color with 100% sRGB color gamut. A rapid 144Hz refresh rate smooths out 2D action. Add the 1ms response time and you've got pixel power. -
Smoothed gaming
Slide through your ride with AMD FreeSync. FreeSync technology eliminates screen tearing and minimizes stuttering by syncing the display refresh rate with the frames output by your computer's display card. PC gaming doesn't get much smoother. -
Vision protected
Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren't the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine. -
All the right moves
Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed. -
It's easy being green
- Acer XF270HUbmijdprz - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 56 kWh
- Power Consumption (On mode)
- 38 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 144 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, HDMI (MHL), DisplayPort, DVI
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 62.37 cm x 24.47 cm x 40.11 cm
- 9.07 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 56 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- eColor Management, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, Blue Light Filter technology
- 62.37 cm x 24.47 cm x 40.11 cm - with stand
- 9.07 kg
Audio
- Speakers
- DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , MHL / HDMI , DVI-D (dual link) , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Input Voltage
- 38 W
- Power Consumption (Typical)
- 28.5 Watt
- Power Consumption Stand by
- 500 mW
- 450 mW
- Dimensions & Weight Details
- With stand - width: 62.37 cm - depth: 24.47 cm - height: 40.11 cm - weight: 9.07 kg , Without stand - width: 62.37 cm - depth: 6.4 cm - height: 37.03 cm - weight: 6.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
