Acer XF270HUbmijdprz 27" 2560x1440 4ms DVI HDMI DP IPS Monitor
PRICE DROP!
Price Drop
Clearance
Quicklinx: BQS6WS00 Mfr#: UM.HX0EE.001
Game like you mean it
Acer XF Series gaming monitors range from Full HD to WQHD resolutions, with aspect ratios from 16:9 up to mega-immersive Ultrawide 21:9. Add to that you get AMD® FreeSync™, a 144Hz2 refresh rate and a 1ms* response time, and you get the gaming you deserve.
Pixel Powered
Acer XF Series monitors are designed to push your pixels to the max. IPS1 technology2 provides wide views and enhanced colour with 100% sRGB colour gamut2. A rapid 144Hz refresh rate2 smooths out 2D action. Add the 1ms response time2 and you’ve got pixel power.
Smoothed gaming
Slide through your ride with AMD® FreeSync™. FreeSync™ technology eliminates screen tearing and minimises stuttering by syncing the display refresh rate with the frames output by your computer’s display card. PC gaming doesn’t get much smoother.
Vision protected
Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren’t the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine.
All the right moves
Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed.
It’s easy being green
The entire XF line also has multiple green design certifications that attest to our commitment to producing products that are both great and green.
  • Nitro XF0
  • Pixel Powered
    Acer XF Series monitors are designed to push your pixels to the max. IPS technology provides wide views and enhanced color with 100% sRGB color gamut. A rapid 144Hz refresh rate smooths out 2D action. Add the 1ms response time and you've got pixel power.
  • Smoothed gaming
    Slide through your ride with AMD FreeSync. FreeSync technology eliminates screen tearing and minimizes stuttering by syncing the display refresh rate with the frames output by your computer's display card. PC gaming doesn't get much smoother.
  • Vision protected
    Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren't the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine.
  • All the right moves
  • It's easy being green
Acer XF270HUbmijdprz - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
56 kWh
Power Consumption (On mode)
38 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, HDMI (MHL), DisplayPort, DVI
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
62.37 cm x 24.47 cm x 40.11 cm
9.07 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
56 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
eColor Management, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, Blue Light Filter technology
62.37 cm x 24.47 cm x 40.11 cm - with stand
9.07 kg
Audio
Speakers
DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , MHL / HDMI , DVI-D (dual link) , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Input Voltage
38 W
Power Consumption (Typical)
28.5 Watt
Power Consumption Stand by
500 mW
Power Consumption (Off Mode)
450 mW
Dimensions & Weight Details
With stand - width: 62.37 cm - depth: 24.47 cm - height: 40.11 cm - weight: 9.07 kg , Without stand - width: 62.37 cm - depth: 6.4 cm - height: 37.03 cm - weight: 6.8 kg
Sustainability Information
ENERGY STAR Certified
