Acer XF270HUAbmiidprzx 27" 2560x1440 DBI+HDMI USB DP Gaming Monit
Quicklinx: CPC1WS00 Mfr#: UM.HX0EE.A01
  • Flicker-less technology
    Reduces annoying screen flickering that can cause eye strain when viewing the monitor for long periods.
  • IPS (In-Plane Switching)
    Colors stay true no matter what angle you're viewing from. Share what's on your screen with friends and family.
Acer XF270HU - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
56 kWh
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, HDMI (MHL), DisplayPort, DVI
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
62.37 cm x 24.47 cm x 40.11 cm
MPR II
Display Type
Energy Class
Class B
56 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
eColor Management, Acer Adaptive Contrast Management (ACM), ComfyView, Mercury free, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Blue Light Filter technology
62.37 cm x 24.47 cm x 40.11 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , MHL / HDMI , DVI-D (dual link) , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Portrait / landscape mode, VESA interface support
1 x DisplayPort cable , 1 x DVI cable , 1 x SuperSpeed USB cable
MPR II
Input Voltage
Dimensions & Weight Details
With stand - width: 62.37 cm - depth: 24.47 cm - height: 40.11 cm , Without stand - width: 62.37 cm - depth: 6.4 cm - height: 37.03 cm
