Acer XF240YUbmiidprzx 23.8" 2560x1440 4ms DVI HDMI DP Monitor
Quicklinx: CP8HWS00 Mfr#: UM.QX0EE.001
  • Nitro XF0
    Game like you mean it
  • Pixel Powered
    Acer XF Series monitors are designed to push your pixels to the max. IPS technology provides wide views and enhanced color with 100% sRGB color gamut. A rapid 144Hz refresh rate smooths out 2D action. Add the 1ms response time and you've got pixel power.
  • Smoothed gaming
    Slide through your ride with AMD FreeSync. FreeSync technology eliminates screen tearing and minimizes stuttering by syncing the display refresh rate with the frames output by your computer's display card. PC gaming doesn't get much smoother.
  • Vision protected
    Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren't the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine.
  • All the right moves
    Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed.
  • It's easy being green
    The entire XF line also has multiple green design certifications that attest to our commitment to producing products that are both great and green.
Acer XF240YU - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, pivot (rotation)
Screen Coating
Anti-glare
54.1 cm x 24.4 cm x 37.5 cm
Display Type
Energy Class
Class B
62 kWh
Diagonal Size
23.8"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay
DVI-D (dual link) , 2 x HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in/out
Mechanical
VESA Mounting Interface
100 x 100 mm
VESA interface support
Limited warranty - 2 years - carry-in
