Acer XF240HBMJDPR  24" 1920x1080 1ms VGA DVI HDMI LED Monitor
Quicklinx: BQRSWS00 Mfr#: UM.FX0EE.001
Smoothed Gaming
Slide through your ride with AMD FreeSync. FreeSync technology eliminates screen tearing and minimises stuttering by syncing the display refresh rate with the frames output by your computer's display card. PC gaming doesn't get much smoother.
All the Right Moves
Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed.
  • Nitro XF0
    Game like you mean it
  • Pixel Powered
    Acer XF Series monitors are designed to push your pixels to the max. IPS technology provides wide views and enhanced color with 100% sRGB color gamut. A rapid 144Hz refresh rate smooths out 2D action. Add the 1ms response time and you've got pixel power.
  • Smoothed gaming
    Slide through your ride with AMD FreeSync. FreeSync technology eliminates screen tearing and minimizes stuttering by syncing the display refresh rate with the frames output by your computer's display card. PC gaming doesn't get much smoother.
  • Vision protected
    Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren't the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine.
  • All the right moves
  • It's easy being green
    The entire XF line also has multiple green design certifications that attest to our commitment to producing products that are both great and green.
Acer XF240Hbmjdpr - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI-D, DisplayPort, HDMI (MHL)
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
56.7 cm x 24.47 cm x 38.55 cm
Display Type
Energy Class
Class B
51 kWh
Diagonal Size
24"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, CCFL edgelight system, ComfyView, Mercury free, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Blue Light Filter technology, 72% NTSC colour gamut
56.7 cm x 24.47 cm x 38.55 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI , MHL / HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Input Voltage
35 W
Power Consumption Stand by
500 mW
Power Consumption (Off Mode)
450 mW
On / Off Switch
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm , With stand - width: 56.7 cm - depth: 24.47 cm - height: 38.55 cm
