Acer XB271HUBMIPRZ 27" 2560x1440 4ms HDMI DP IPS Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: BQSCWS00 Mfr#: UM.HX1EE.005
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
20 in stock
£582.84 ex VAT
£699.40 inc VAT
In competitive gaming, every frame matters. Introducing Acer's XB Series Series WQHD gaming monitor that can keep up with your game play. Through NVIDIA G-Sync technology, on-screen action is smooth and clear, minimizing distractions, boosting response times, and giving you a serious competitive edge. Plus, users can enjoy comfortable viewing experience while gaming via flicker-less, low dimming and ComfyView display.
Acer XB 27" monitor features WQHD resolution (2560 x 1440) presenting stunning, high quality images with excellent detail that not only enhances users' working efficiency, but creates outstanding visual enjoyment. NVIDIA G-SYNC technology synchronizes the monitor's refresh rate to the GPU render rate providing the smoothest, fastest gaming experience. G-SYNC even eliminates screen tearing and minimizes display stutter and input lag when users start playing games so scenes appear instantly and sharper.
Acer Predator XB271HU - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1
Response Time
4 ms
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Microsoft Certification
Compatible with Windows 7
Display Type
Energy Class
Class B
60 kWh
41 W
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
100000000:1
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Matte, ComfyView, 100% sRGB colour gamut, Zero Frame, NVIDIA Ultra Low Motion Blur Technology, Flicker-Less technology, Low Dimming technology, Blue Light Filter technology, Predator GameView technology
Audio
Speakers
DisplayPort , USB 3.0 upstream , HDMI , 4 x USB 3.0 downstream
Mechanical
Aluminum enclosure, Acer Eyeprotect technology
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable
On / Off Switch
Acer XB271HUBMIPRZ 27 Bundle deal on Acer XB271HUBMIPRZ 27" 2560x1440 4ms HDMI DP IPS Monitor
£682.01
BQSC C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BQSC C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.68
BQSC C2G 5m Select High Speed HDMI with Ethernet In Stock £22.32
BQSC C2G 10m Select High Speed HDMI with Ethernet In Stock £42.89
BQSC C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 500 - 750
