Acer XB270HUDBMIPRZ 27" 2560x1440 1ms HDMI DP LED Monitor
Quicklinx: BQSBWS00 Mfr#: UM.HB0EE.D01
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£452.28 ex VAT
£542.73 inc VAT
Fasten your seatbelt: Acer's premium XB Series monitors are about to turbocharge your gaming experience. These monitors combine cutting-edge technologies to deliver great gaming experiences. Plus, built-in eye protection and ergonomics allow you to press forward into battle without fatigue.
  • G-SYNC & Ultra HD
    These are the world's first monitors that combine NVIDIA G-SYNC technology with Ultra HD 4K2K resolution. This means you get no tearing, no stuttering - just buttery smoothness on more pixels for sharper game scenes.
  • Ultra-fluid motions
    A rapid 144Hz refresh rate and blazingly fast 1ms response time deliver ultra-smooth motion scenes. Ultra Low Motion Blur (ULMB) technology makes moving objects appear perfectly sharp, with no visible blurring. Let the lower latency and immersive graphics of these monitors vastly improve your gaming experience.
  • Eye protection
    These monitors help to reduce eye strain with Flicker-less, low-dimming, and anti-glare technologies. Flicker-less technology reduces screen flickering, which is a major cause of eye strain for people who look at monitors for long periods. Acer ComfyView technology cuts screen glare to further reduce eye strain.
  • Ergonomic setup
    The Acer ErgoStand lets XB Series monitors pivot, tilt, swivel, and move up or down, so you can find the most comfortable angle from where to oversee your push into enemy territory.
Predator XB270HU - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
63.97 cm x 24.47 cm x 55.81 cm
TCO Displays
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, ComfyView, nVidia 3D Vision
63.97 cm x 24.47 cm x 55.81 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , USB 3.0 , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Acer Eyeprotect technology
TCO Displays
On / Off Switch
Dimensions & Weight Details
With stand - width: 63.97 cm - depth: 24.47 cm - height: 55.81 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
Acer XB270HUDBMIPRZ 27 Bundle deal on Acer XB270HUDBMIPRZ 27" 2560x1440 1ms HDMI DP LED Monitor
£551.45
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 300 - 500
