Product
Acer XB240Hbmjdpr 24" 1920x1080 1ms VGA DVI HDMI DP LED Monitor
With a rapid refresh rate and blazing fast response time!
Quicklinx: 9ZSXWS00 Mfr#: UM.FB0EE.001
These are the world's first monitors that combine NVidia 3D Vision technology with Ultra HD resolution. This means you get no tearing, no stuttering - just buttery smoothness on more pixels for sharper game scenes. A rapid refresh rate and blazingly fast response time deliver ultra-smooth motion scenes. Ultra low motion blur technology makes moving objects appear perfectly sharp, with no visible blurring. Let the lower latency and immersive graphics of these monitors vastly improve your gaming experience.
These monitors help to reduce eye strain with Flicker-less, low-dimming, and anti-glare technologies. Flicker-less technology reduces screen flickering, which is a major cause of eye strain for people who look at monitors for long periods. Acer ComfyView technology cuts screen glare to further reduce eye strain. The Acer ErgoStand lets XB series monitors pivot, tilt, swivel, and move up or down, so you can find the most comfortable angle from where to oversee your push into enemy territory.
  • NVidia 3D Vision and Ultra HD
  • Ultra-fluid motions
  • Eye protection
  • Ergonomic setup
Acer XB240Hbmjdpr - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
49 kWh
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, MHL, DVI, DisplayPort, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
2 years warranty
Display Type
Energy Class
Class C
49 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), matte, ComfyView, nVidia 3D Vision, Flicker-Less technology
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DisplayPort , VGA , DVI , MHL / HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x DVI cable , 1 x VGA cable
TCO Displays 6.0
Power Supply
Internal
AC 120/230 V
23 Watt
Power Consumption Stand by
500 mW
Power Consumption Sleep
450 mW
ENERGY STAR Certified
9ZSX C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9ZSX C2G 5m Select High Speed HDMI with Ethernet In Stock £20.88
9ZSX C2G 10m Select High Speed HDMI with Ethernet In Stock £40.08
9ZSX C2G 15m Select High Speed HDMI with Ethernet In Stock £54.29
9ZSX C2G Pro HDMI to VGA Converter In Stock £50.07
