Acer X138WH WXGA 3700 Lumens DLP Projector
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: DHQ7WS00 Mfr#: MR.JQ911.002
  • Bright and vivid
    With WXGA resolution, high brightness, high contrast and Acer Color Technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D Ready you can also enjoy an immersive theater-like 3D entertainment experience.
  • Acer Dust Shield
    The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance.
  • Convenient and flexible
    Essential series projectors have features that make them easy to use including 9 key control panels on the top of the projectors and 40-degree keystone correction that automatically adjusts vertical distortions. Their ceiling mounts provide four ways to install them so you can pick the method that best suits your needs.
  • Eco-smart
    Essential series projectors sport eco-friendly technologies that are better for the planet and good for your wallet. Their standby power consumption can be reduced by 90% and by 70% when powered on, which helps to prolong the lifespan of its lamps (up to 10,000 hours) for lower replacement costs.
Acer X138WH - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3700 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
P-VIP 203 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode , Up to 10000 hour(s) - extreme economic mode
Video Input
(PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
240 Watt
31.1 cm x 24 cm x 11.37 cm
2.7 kg
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3700 ANSI lumens
Brightness (Reduced)
2960 ANSI lumens
Contrast Ratio
20000:1
Image Size
76.2 cm - 762 cm
Projection Distance
1.1 m - 10 m
Throw Ratio
1.54 - 1.72:1
Uniformity
80 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 203 Watt
Bulb life cycle
6-segment colour wheel, High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, ColorBoost 3D Technology, rear projection, ExtremECO, Acer LumiSense, Acer Bluelight Shield
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A
Lens cover, wireless remote control
1 x VGA cable
FCC, ROSTEST
Nominal Voltage
AC 120/230 V
240 Watt
Power Consumption Stand by
0.5 Watt
31.1 cm
24 cm
11.37 cm
2.7 kg
80%
Sound Emission
30 dBA
24 dBA
