Acer X1385WH TCO 1200x800 3100 Lumens 3D Projector
Quicklinx: BMKHWS00 Mfr#: MR.JL511.002
Bright and Vivid
With WXGA resolution1, high brightness, high contrast and Acer Color Technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP® 3D Ready2 you can also enjoy an immersive theater-like 3D entertainment experience.
Acer Dust Shield
The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance.
Convenient and flexible
Essential series projectors have features that make them easy to use including 9 key control panels1 on the top of the projectors and 40-degree keystone correction that automatically adjusts vertical distortions. Their ceiling mounts provide four ways to install them so you can pick the method that best suits your needs.
Eco-smart
Essential series projectors sport eco-friendly technologies that are better for the planet and good for your wallet. Their standby power consumption can be reduced by 90% and by 70% when powered on, which helps to prolong the lifespan of its lamps (Up to 10,000 hours) for lower replacement costs.
Acer X1385WH - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
P-VIP 230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
S-Video, composite video (SECAM, PAL)
Speakers
Speaker(s) - integrated
AC 120/230 V
253 Watt
30.8 cm x 21.1 cm x 8.6 cm
2.2 kg
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Brightness (Reduced)
2560 ANSI lumens
Contrast Ratio
20000:1
Image Size
71 cm - 762 cm
Projection Distance
1 m - 9.2 m
Throw Ratio
1.5 - 1.65:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 230 Watt
Bulb life cycle
6-segment colour wheel, High-bandwidth Digital Content Protection System (HDCP), ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support, Auto Power Off, MHL compliance, Quick-Start
Lens
Focus Type
Manual
Lens Aperture
F/2.56-2.8
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
SECAM, PAL
Analogue video Signal
Video Interfaces
HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone 3.5 mm
Wireless remote control
1 x VGA cable
GS, FCC, ROSTEST
Power Source
AC
AC 120/230 V
253 Watt
Power Consumption Stand by
0.5 Watt
30.8 cm
21.1 cm
8.6 cm
2.2 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
30 dB
26 dB
BMKH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
