Acer X137WH WXGA 3700 Lumens DLP Projector
Quicklinx: D59SWS00 Mfr#: MR.JP411.002
  • Bright and vivid colors
    With resolution, brightness and contrast at a high level, your presentations will become fascinating, texts will become clearer, and colors will become more vivid and crisp even from long distances.
  • Acer Dust Shield
    Dust buildup can, over time, cause the projector to stop working properly and lose its initial brightness. The Acer Dust Shield solution protects Essential projectors from the negative effects of dust, so the devices perform better and last longer, and projector maintenance becomes much easier.
  • Convenient and flexible
    The Essential projectors are equipped with features that make them easy to use, such as a control panel on the top of the projector and a 40-degree keystone correction function that automatically adjusts vertical distortion.
Acer X137WH - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3700 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
P-VIP 195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V
235 Watt
31.4 cm x 22.3 cm x 9.3 cm
2.5 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3700 lumens
Brightness (Reduced)
2960 lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
75 cm - 762 cm
Projection Distance
1.1 m - 10 m
Throw Ratio
1.54 - 1.72:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 195 Watt
Bulb life cycle
6-segment colour wheel, BrilliantColor, Instant Pack Technology, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, ExtremECO
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
Video Modes
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management)
Wireless remote control
FCC, ROSTEST
Power Source
AC
AC 120/230 V
235 Watt
Power Consumption Stand by
0.5 Watt
31.4 cm
22.3 cm
9.3 cm
2.5 kg
0 - 80%
Sound Emission
31 dBA
28 dBA
