Acer X123PH features a variety of functions including the following. ColorBoost 11+ is an advanced feature which refines the waveform to improve optical color performance based on lamp spectrum and colorwheel properties. ColorBoost 11+ brings natural color temperature: improving natural color temperature from a refined waveform to achieve optical color balance. Content-based color brightness improvement: combining Acer eView Management which offers varied scenario modes with color-specific refined waveform to improve color brightness according to content
With DLP 3D ready, user can view any 120 Hz 3D frame sequential content from a PC with appropriate 120 Hz graphic card and 3D stereoscopic player or any Blu-ray Disc title from a Blu-ray Disc (BD) player and HQFS 3D DVD title from an NTSC DVD player by wearing DLP 3D glasses.
Acer projectors featuring ColorSafe II are virtually immune to color decay, such as the yellow or green tint on images displayed by some projectors that have been used for extended periods of time. Acer projectors take advantage of DLP technology to guarantee picture integrity even with prolonged use. Extended lifespan and consistent image quality lower the total cost of ownership and translate to big savings.
Acer EcoProjection is a complete environment-friendly power management solution that reduces standby power consumption by up to 90%, from 5 W to 0.5 W. Also featured in the Acer EcoProjection suite is Acer ePower Management for customized power-saving configurations.
Acer ColorBoost 11+
ColorBoost 11+ is an advanced feature which refines the waveform to improve optical color performance based on lamp spectrum and colorwheel properties. ColorBoost 11+ brings natural color temperature: improving natural color temperature from a refined waveform to achieve optical color balance. Content-based color brightness improvement: combining Acer eView Management which offers varied scenario modes with color-specific refined waveform to improve color brightness according to content -
DLP 3D Ready
With DLP 3D ready, user can view any 120 Hz 3D frame sequential content from a PC with appropriate 120 Hz graphic card and 3D stereoscopic player or any Blu-ray Disc title from a Blu-ray Disc (BD) player and HQFS 3D DVD title from an NTSC DVD player by wearing DLP 3D glasses. -
Acer ColorSafe II
Acer projectors featuring ColorSafe II are virtually immune to color decay, such as the yellow or green tint on images displayed by some projectors that have been used for extended periods of time. Acer projectors take advantage of DLP technology to guarantee picture integrity even with prolonged use. Extended lifespan and consistent image quality lower the total cost of ownership and translate to big savings. -
Acer EcoProjection
- Acer X123PH - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3000 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- P-VIP 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Power
- AC 120/230 V
- 235 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3000 lumens
- Brightness (Reduced)
- 2400 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Image Size
- 57 cm - 762 cm
- Projection Distance
- 1 m - 11.9 m
- Throw Ratio
- 1.95 - 2.15:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 190 Watt
- Bulb life cycle
- 6-segment colour wheel, BrilliantColor, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.55
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
- 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- FCC, ROSTEST
- Voltage Required
- AC 120/230 V
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- 0 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
