Acer X123PH DLP XGA 3D 3000 Lumens Projector
Quicklinx: BCWCWS00 Mfr#: MR.JKZ11.002
Acer X123PH features a variety of functions including the following. ColorBoost 11+ is an advanced feature which refines the waveform to improve optical color performance based on lamp spectrum and colorwheel properties. ColorBoost 11+ brings natural color temperature: improving natural color temperature from a refined waveform to achieve optical color balance. Content-based color brightness improvement: combining Acer eView Management which offers varied scenario modes with color-specific refined waveform to improve color brightness according to content
With DLP 3D ready, user can view any 120 Hz 3D frame sequential content from a PC with appropriate 120 Hz graphic card and 3D stereoscopic player or any Blu-ray Disc title from a Blu-ray Disc (BD) player and HQFS 3D DVD title from an NTSC DVD player by wearing DLP 3D glasses.
Acer projectors featuring ColorSafe II are virtually immune to color decay, such as the yellow or green tint on images displayed by some projectors that have been used for extended periods of time. Acer projectors take advantage of DLP technology to guarantee picture integrity even with prolonged use. Extended lifespan and consistent image quality lower the total cost of ownership and translate to big savings.
Acer EcoProjection is a complete environment-friendly power management solution that reduces standby power consumption by up to 90%, from 5 W to 0.5 W. Also featured in the Acer EcoProjection suite is Acer ePower Management for customized power-saving configurations.
  • Acer ColorBoost 11+
  • DLP 3D Ready
  • Acer ColorSafe II
  • Acer EcoProjection
Acer X123PH - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3000 lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
P-VIP 190 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
AC 120/230 V
235 Watt
31.4 cm x 22.3 cm x 9.3 cm
2.5 kg
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
57 cm - 762 cm
Projection Distance
1 m - 11.9 m
Throw Ratio
1.95 - 2.15:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 190 Watt
Bulb life cycle
6-segment colour wheel, BrilliantColor, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
1 x composite video input - RCA , 1 x S-video input - mini-DIN , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
FCC, ROSTEST
AC 120/230 V
235 Watt
Power Consumption Stand by
0.5 Watt
31.4 cm
22.3 cm
9.3 cm
2.5 kg
Sound Emission
31 dBA
28 dBA
BCWC C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
