Whether you're projecting business presentations, academic lectures or photographs, draw your audience in with immersive 3D. Colors remain balanced and images accurate with advanced Acer technologies. Everything looks sharp and real thanks to exceptional resolution and high brightness.
Launch right into your concepts with a customized startup screen. Modify power, viewing and timer settings with the one-touch empowering key. Broaden your viewpoint by instantly projecting wide-format content without complicated resolution tinkering. And you can safely unplug as soon as the projector is off.
Captivating
Whether you're projecting business presentations, academic lectures or photographs, draw your audience in with immersive 3D. Colors remain balanced and images accurate with advanced Acer technologies. Everything looks sharp and real thanks to exceptional resolution and high brightness. -
Flexible
Launch right into your concepts with a customized startup screen. Modify power, viewing and timer settings with the one-touch empowering key. Broaden your viewpoint by instantly projecting wide-format content without complicated resolution tinkering. And you can safely unplug as soon as the projector is off. -
Convenient
Display your ideas just how you want with keystone correction. Pan across presentations and zoom in on important points. Attach multiple devices via dedicated connectors. Lamp replacement is simple, even when the projector is ceiling mounted, with the easy access of an excellent design. -
Eco-smart
Acer EcoProjection reduces power in standby mode to as little as a single watt to conserve energy and protect the environment. Earth-friendly elements include long lamp life for lower replacement cost and dependable use, an eco mode, and automatic sleep or shutdown after a pre-set period.
- Acer X113PH - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Localisation
- United Kingdom, Europe
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- P-VIP 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Power
- AC 120/230 V
- 235 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- DLP projector
- 3D Capable
- Localisation
Projector
- Brightness
- 3000 ANSI lumens
- Brightness (Reduced)
- 2400 ANSI lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Image Size
- 58.4 cm - 762 cm
- Projection Distance
- 1 m - 11.9 m
- Throw Ratio
- 1.95 - 2.15:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 190 Watt
- Bulb life cycle
- BrilliantColor, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology
Lens
- Lens Aperture
- F/2.41-2.55
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- GS, FCC, ROSTEST
- Voltage Required
- AC 120/230 V
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- 0 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
