Acer X113P 800x600 2800 Lumens SVGA 3D Projector
Quicklinx: BMKLWS00 Mfr#: MR.JM311.002
Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D Ready, while adhering to your bottom line.
  • Bright and vivid
    With WXGA resolution, high brightness, high contrast and Acer Color Technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D Ready you can also enjoy an immersive theater-like 3D entertainment experience.
  • Acer dust shield
    The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance.
  • Convenient and flexible
    Essential series projectors have features that make them easy to use including 9 key control panels1 on the top of the projectors and 40-degree keystone correction that automatically adjusts vertical distortions. Their ceiling mounts provide four ways to install them so you can pick the method that best suits your needs.
  • Eco-smart
    Essential series projectors sport eco-friendly technologies that are better for the planet and good for your wallet. Their standby power consumption can be reduced by 90% and by 70% when powered on, which helps to prolong the lifespan of its lamps for lower replacement costs.
Acer X113P - DLP projector - portable - 3D
DLP projector
3D Capable
United Kingdom
Brightness
3000 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
AC 120/230 V
235 Watt
31.4 cm x 22.3 cm x 9.3 cm
2.5 kg
DLP projector
3D Capable
United Kingdom
Projector
Brightness
3000 lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
58 cm - 762 cm
Projection Distance
1 m - 11.9 m
Throw Ratio
1.95 - 2.15:1
Digital Zoom Factor
2x
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
190 Watt
Bulb life cycle
16:9 aspect ratio support, 4:3 aspect ratio support
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
1 x VGA input , 1 x S-video input , 1 x composite video input , 1 x USB (management)
Wireless remote control
1 x VGA cable
AC 120/230 V
235 Watt
31.4 cm
22.3 cm
9.3 cm
2.5 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
31 dB
28 dB
