Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D Ready, while adhering to your bottom line.
Bright and vivid
With WXGA resolution, high brightness, high contrast and Acer Color Technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D Ready you can also enjoy an immersive theater-like 3D entertainment experience. -
Acer dust shield
The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance. -
Convenient and flexible
Essential series projectors have features that make them easy to use including 9 key control panels1 on the top of the projectors and 40-degree keystone correction that automatically adjusts vertical distortions. Their ceiling mounts provide four ways to install them so you can pick the method that best suits your needs. -
Eco-smart
Essential series projectors sport eco-friendly technologies that are better for the planet and good for your wallet. Their standby power consumption can be reduced by 90% and by 70% when powered on, which helps to prolong the lifespan of its lamps for lower replacement costs.
- Acer X113P - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Localisation
- United Kingdom
- Brightness
- 3000 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Power
- AC 120/230 V
- 235 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- 2-year warranty
- DLP projector
- 3D Capable
- Localisation
- United Kingdom
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 58 cm - 762 cm
- Projection Distance
- 1 m - 11.9 m
- Throw Ratio
- 1.95 - 2.15:1
- Digital Zoom Factor
- 2x
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- 16:9 aspect ratio support, 4:3 aspect ratio support
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.55
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- 1 x VGA input , 1 x S-video input , 1 x composite video input , 1 x USB (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- AC 120/230 V
- 235 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 28 dB
