Acer X1126H XGA 4000 Lumens DLP Projector
Quicklinx: D59TWS00 Mfr#: MR.JPA11.002
Acer Essential series projectors are optimal-value projectors, ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D ready, while adhering to your bottom line.
Acer X1226H - DLP projector - portable - 3D
DLP projector
3D Capable
Brightness
4000 lumens
Contrast Ratio
20000:1 (dynamic)
Bulb type
220 Watt
Video Input
RGB, S-Video, composite video
31.5 cm x 21.4 cm x 9.8 cm
2.65 kg
DLP projector
3D Capable
Projector
Brightness
4000 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
XGA
Bulb type
220 Watt
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
31.5 cm
21.4 cm
9.8 cm
2.65 kg
